BQ25120F3A: With TPS62088
Part Number: BQ25120F3A
Other Parts Discussed in Thread: TPS62088, BQ21061, BQ2970
Hello TI Team!
Quick question - I'm looking into using the BQ25120F3A for an application where the MCU may draw above the 300mA current limit of the BQ25120F3A. I was thinking of using BQ25120F3A for battery charging, wakeup, and powering sensors, and using a separate TPS62088 directly powered by the battery voltage (bypassing the BQ25120F3A), which would be enabled after BQ25120F3A wakes up from ship mode.
Do you foresee any significant issues with this approach? Wanted to confirm that the BQ25120F3A power management will operate as expected with a second regulator being driven by the battery voltage.
Thank you!
Tyler
