Other Parts Discussed in Thread: TPS65400,
Hello
Can you review the schematics of TPS546x and TPS65400 for me?
Hello
Hi Zhao,
Our US team will review it then reply you soon.
What design tool was used to develop the 4 TPS546B24A designs?
Have you filled out a the schematic review check-list? https://www.ti.com/lit/zip/slurb01
All of the designs are listing compensation coming from default NVM. Are you planning to program this prior to first power-up, or are you expecting the default NVM value to be stable? If you are programming it, please enter the desired programming values into the design check list.
Why does the design use the same 6-pin header with 3 enable options? Is this an evaluation board that needs different enable options?
I will ask someone from the TPS65400 team to review those 8 outputs.
Reply:TPS546x24A Compensation and Pin-Strap Resistor Calculator , www.ti.com/.../SLUC686
Reply:NO,I don't have this, thanks for sharing
Reply:Plan to program this prior to first power-up.
Reply:Yes,need different enabling options
At the same time, please help to check whether the output inductance and capacitance are correct,Tks
