Other Parts Discussed in Thread: TPS23755, PMP7355
Hi Expert,
My customer is using TPS23758 in their IP CAM product. They need the 5V/ single output. Based on their request, we have proposed the TPS23758 to them.
Recently they are doing the test on our EVM board, and want to make some modification. They ask some question regarding to TPS23755 and Diode Rectify. I have checked other discussion thread in E2E and see there are some discussion regarding to above questions. However still have some item need your help.
1. Customer replace the SR MOS by Diode on TPS23758EVM. They found output voltage change from 5V to 10V. From my understating the Diode mainly affect the efficiency, why the output voltage also change?
2. Do TPS23758 has internal algorithm for the SR control? Because the parameter of 755 and 758 looks like the same, customer want to know the detail of the difference.
Thank you!
Pin
