All the suggested inductors & capacitors on TPS65632 datasheet are no longer available. Would you be able to suggest drop-in replacements?
Thanks in advance
Thanks in advance
Hello Alex,
You can use:
DFE252012C-4R7N for 4.7uH inductor. I believe they are available at mouser.
DFE252012C-100M for 10uH inductor which is available at digikey.
Any capacitors with similar specification to what is listed in the datasheet should work and there are many choices at digikey and mouser. For example, LMR212BD7106KG-T at mouser.
Kind Regards,
Liaqat
Thanks for the reply Liaqat. By the way on your demo board here https://www.ti.com/lit/ug/slvual2/slvual2.pdf?ts=1632998711914 at page 12, there is a mistake on the inductors description
Thank you Alex for pointing it out. We will correct it in the next revision of the document.
Have a nice weekend.
Kind Regards,
Liaqat
