Other Parts Discussed in Thread: BQ500212A
Hello TI Support team,
I have a project with BQ51013B and I need to calibrate FOD resistor since I do have metal around the charge coil. As you already know the Aid tool is not available anymore and all of TI documents are based on that tool. also bq500212A is not available and the information is not much to use it even if it was. I need your help please to see if there is any other way to calibrate FOD. I can measure every specs in my system and also the amount of TX power that I am planning to use.
Amin Rahmati.
