TPS7H5001-SP: Unable to sim transient model in PSpice for TI
Part Number: TPS7H5001-SP
I'm trying to run the default sim, the push pull example circuit for this transient model. I get this error message:
ERROR(ORPSIM-15108): Subcircuit VCO_SQR used by X_U2.X_U14 is undefined
ERROR(ORPSIM-15108): Subcircuit AWBONE_SHOT used by X_U2.X_U41 is undefined
Do you know what I could be down wrong? Thanks
  • Hey Andre,
    What simulation software are you using when running this simulation?
    Daniel
  • Hi Daniel, I'm using PSpice for TI 17.4-2021 S007
  • Hey Andre,
    I was able to confirm your issue on my end.
    I believe this is either an issue of us giving incomplete files or with the model.
    I will continue to investigate this and give updates as I go.
    Daniel
  • A Good that some others have also the same Problem :) Hope they update the model as soon as possible, that i can go on with my tests with this chip. I use TINA. 9.3
  • Hey Josef,
    Are you seeing the exact same issue or a similar one?
    Daniel
  • Hey Josef/Andre,
    I have confirmed this is a common issue between free PSPICE simulators that is not common with the paid versions.
    I am still investigating if there is a solution available.
    Daniel
  • Hi Daniel,
    I get the same Problem with the VCO_SQR as Andre gets.
    "Undefined subcircuit: VCO_SQR. (C:\Program Files (x86)\DesignSoft\Tina 9 - TI\EXAMPLES\SPICE\TSPICE.LIB)
    But i get only the VCO_SQR displayed. Tina stop, as i see, at the first error and does not check the rest.
    That could also be fixed in Tina, to get all the problems in one punch instead of going one after the other Slight smile.
    Josef
  • Thank you for the information Josef.
    Daniel
  • Hey Josef/Andre,
    After conversing with our internal modeling team, there is a library that is common to paid versions of PSPICE simulators that the model currently calls.
    There is not a way to make this compatible with the current TPS7H5001-SP model without changes to the model.
    While we plan to do this in the future, I cannot give an updated date for when this will be completed.
    I will update both of you when this gets done, but for now I will close the thread.
    Daniel
  • Hey Daniel,
    thx for the info. That info should be added at the spice model download, or in the spice file as comment,
    that the people know that in advance :).
    As long this is not resolved, can you give me a link where i can get this library?
    Josef
  • Hey Josef,
    The library name is called anl_misc.lib.
    This I believe is only available to paid versions of the PSPICE simulators.
    I am not the simulation program expert, and if you have questions about the simulators my suggestion would be to open a new E2E about this specific topic.
    This allows you to ask the question directly to our simulation program experts.
    Daniel
  • If you are using the model in LTSpice you can include the following statements as Spice Directives in the schematic and it seems to allow the model to function.
    .subckt vco_sqr in out Params: Fcenter=2e6 Frange=2e6 Vmin=0 Vmax=4MEG
    +phase=0
    Rin             in              0               1G
    Rtable  table   0               1G
    Etable  table   0       Value {Table(V(in),Vmin,-1,Vmax,1)}
    Esin            sine            0
    +Value {sin(6.28318*(Fcenter*time+Frange*SDT(V(table)))+phase*(3.14159/180))}
    Esqr            out             0               table {V(sine)} (0,0) (1n,1)
    .ends
    .SUBCKT AWBONE_SHOT 1 11 8 PARAMS: DELAY= 1U
    .PARAM CC={0.002*DELAY}
    SS10 9 0 8 0 MS1MSS10
    .MODEL MS1MSS10 VSWITCH VT=499.999970M VH=1N RON=1G ROFF=1M
    II8 0 9 1.000000M
    CC1 9 0 {CC}
    SS9 5 4 11 0 MS2MSS9
    .MODEL MS2MSS9 VSWITCH VT=499.999970M VH=1N RON=1 ROFF=1MEG
    SS8 5 4 9 0 MS2MSS9
    II7 0 4 -2U
    VV3 5 0 1
    II6 0 2 2U
    SS7 0 2 4 0 MS2MSS9
    SS6 0 2 1 0 MS2MSS9
    II5 0 7 1U
    SS5 0 7 4 2 MS3MSS5
    .MODEL MS3MSS5 VSWITCH VT=0 VH=499.999970M RON=1 ROFF=1MEG
    GV2 0 6 7 0 2U
    SS4 6 0 2 0 MS4MSS4
    .MODEL MS4MSS4 VSWITCH VT=499.999970M VH=1.000000N RON=1K ROFF=1MEG
    II4 6 0 1U
    II3 0 8 1U
    SS3 8 0 6 0 MS5MSS3
    .MODEL MS5MSS3 VSWITCH VT=0 VH=499.999970M RON=1MEG ROFF=1
    GV1 0 3 0 0 -2U
    SS1 3 0 1 0 MS4MSS4
    II1 3 0 -1U
    II2 0 7 1U
    SS2 7 0 3 0 MS5MSS3
    .ENDS AWBONE_SHOT
  • Hey Thomas,
    I can confirm that is actually what we are trying to implement into the model now and get it released.
    The problem specific to PSPICE for TI is that there is a limit on the number of traces probed.
    TINA may not have an issue, but this is certainly a fix for LTSPICE.
    I will update the forum here when we get through the release process.
    Daniel
    I have confirmed that we have an updated model releasing either Monday or Tuesday that should fix this problem.
    If you continue to have issues please contact us again after these dates.
    Daniel
