Other Parts Discussed in Thread: TPS3899, TPS3808, TPS3890
Do you know if there’s any pin compatible solutions for the TPS3808G01MDBVTEP?
I was using in a hysteresis application per https://www.ti.com/lit/an/slva360/slva360.pdf?ts=1633721187812&ref_url=https%253A%252F%252Fwww.google.com%252F#:~:text=For%20the%20TPS3808%2C%20the%20inherent,battery%20voltage%20(V1%E2%80%93).
I don’t believe I can accomplish the same thing with the (at least to the same levels) fixed versions since that’s all you guys have in stock.
Adam
