Other Parts Discussed in Thread: BQ76930, BQ78350-R1, BQ78350
I am thinking to use both BQ78350-R1A and BQ76930 for the BMS design. I am not sure about the fault handling by BQ78350-R1A and BQ76930 combination.
Based on the BQ76930 data sheet, there are integrated hardware protections in BQ76930.
My questions: If there is fault (e.g. overvoltage), is the BQ78350-R1A or BQ76930 turn off the CHG/DSG FET? Or BQ78350-R1A is used to set the BQ76930 fault threshold only and BQ76930 will turn off the FET (e.g turn off CHG FET for OV fault)?
For permanent failure, if the cell voltage is > SOV threshold, BQ78350-R1A will send the command to BQ76930 to turn off all the CHG, DSG & PCHG FETs. Am i right?
Thansk!
