TPS62402-Q1: 62424/62423 efficiency curves
Part Number: TPS62402-Q1
Hi team,
Here is the efficiency in  TPS624xx-Q1 datasheet but only have 62407/62406/62422 curves and no 62424/62423 curves
For 62424/62423 ,which one should customer refer to?
  • Hi Amelie,
    You can use the efficiency curve near to output range from curves given in datasheet. All devices share similar design architecture and only define for different output range.
    I would not expect any drastic difference for efficiency curves.
    Tanvee
