The data sheet for the TPS50601A-SP lists the error amp gm as being between 1000uS and 2000uS with a typical value of 1400 uS.
Looking at the average Pspice file for the TPS50601A (download file SLVMCL4A.ZIP), it looks like the simulation has the gm of the error amplifier set to 1750u in this equation:
G_ABM2I1 GND COMP VALUE { LIMIT(((V(N1165059) - V(VSENSE))
+ *1750u),-125u,125u) }
This value is between the data sheet limits, but higher than the nominal value of 1400uS. Why is the Pspice value set to the higher end of the range? Is this based on aligning the simulation result with the actual measured results?
