Other Parts Discussed in Thread: TPS63030
We are switching from a TPS63030 to TPS63000 due to part availability. The TPS63000 part seems to work for a while but it gets
very hot and will eventually fail. When it fails there is a low resistance from the Lx pins and ground. The part is powered from a USB 5V
and we adjust the output between 2V and 5V. Most testing so far has been with no load or a low load. We only need 100ma from the device.
Same schematic but we added a cap to the input to reduce noise. The PCB footprint changed for the new part. So far we blew 3 parts.
