Hello TI expert:
I use UCC28780, Navitas GanIC(NV6115), and MPS SR IC(MP6908A) for active clamp flyback solution.
Follow "Debugging UCC28780 ACF Converter Start-up Issues" document, I have already seen 4 PWML pulse under brown in situation.
Although I have disabled SR controller and changed high side GaN to general diode (change general MOSFET & short Vgs), the abnormal waveform still occur when Vin> brown in voltage.
PWML bounce when should be turned off period, it will cause Vcs become higher to reach OPP level. Because PWML will retry after about 1.36s.
And also I notice RNU pin will drop and bounce when PWML turns off
Do you have any similar experience? Can you give me some suggestions?
Thanks.
