Other Parts Discussed in Thread: BQ24179
For the parts based on BQ25790 (in particular BQ24179), After reading through the datasheet and EVM guide, I'm still not exactly sure of the purpose of the PMID pins. Is this only to be used in OTG use-cases? Even with OTG use-cases, why not just use VBUS?
What if I have no use for OTG? Can I leave PMID floating or are the recommended capacitors necessary even if I don't plan to drive anything from PMID?
Also curious if there is a different part that you'd recommend that doesn't include OTG support?
Christopher
