LM2674: Buck regulate a positive and negative Vout
Part Number: LM2674
Other Parts Discussed in Thread: LM22674, LMR50410, LMR33610
Looking to make a pair of adjustable output voltage buck regulators (from a microcontroller)
Vin = +24v, Vout = +10 to +18v, Iout = 100mA (max.), AND separately
Vin = -24v, Vout = -10 to -18v, Iout = -100mA (max.)
QUESTIONS
a) For the positive, looks like LM2674 should work (although current limit is too high). Any other suggestions?
b) Is there a clever circuit to use the same buck regulator part number (but a second copy of that IC) for the negative regulation also? I plan to regulate Vout+ and Vout- independently of each other by the microcontroller.
Thanks.
  • Hello
    The LM2674 is OK for your application.
    Other devices you might consider are the LM22674, LMR33610, LMR50410
    I have attached some information about using a uC as a DAC to adjust your Vout. (you may need a filter if you are using PWM from the uC)
    If you have a -24V rail, then the simplest thing to do is to use a negative linear regulator for your negative Vout.
    You can use an ordinary buck as an inverting converter (IBB).  You would use your +24V rail and convert to your negative Vout.
    However, it is somewhat tricky to do the DAC with an IBB.  You will need level shifting.
    I have attached some information on the IBB that may be helpful.
    3733.snva856a.pdf
    8358.DAC_calc5.xlsx
  • Frank
    Excellent inputs on this. A few comments:
    a) I prefer not to use +24v to also generate the negative output rail. I prefer to use the -24v rail to generate the negative Vout. I have a lot of these regulators in the system, and I want to balance current loads on the +24v and -24v supplies (if possible).
    b) Regulating the negative voltage with a microprocessor should be easy since I plan to use PWM from the micro, and this can be AC coupled. I prefer to stay away from a DAC to control the output. Also, I will probably implement a feedback loop to the micro (which has a lot of 10-bit ADC inputs) to tightly control +Vout and -Vout (using perhaps an inverting op-amp).
    Thanks.
  • Hello
    OK.  I will close this post for now.
    If you would like us to review your final design, don't hesitate to contact us.
