Other Parts Discussed in Thread: TPS544C20,
We are seeing very inaccurate output current readings from the device across multiple samples. We have two similar designs, one based on TPS544C20, and another based on TPS544B20. Both exhibit a wide range of readings across multiple assemblies.
Design details:
1: TPS544C20, 5V input, 3.3V output, 15A max output current
2: TPS544B20, 5V input, 0.8V output, 11A max output current
With the application board running in an "idle" mode, we typically expect about 6-7 Amps for the first design. However, the readings (depending on the assembly measured on) range from 1A to 9A!
We'd like to understand:
a. what we can expect in terms of accuracy for the output current reading
b. what may be the source of error/variation from board to board.
Thanks for your support.
B. Assar
