Hi:
I'm trouble shooting a circuit of TPS65100, the schematic is below, it's pretty much the same as the eval board except a few part values. The circuit works fine when I power it on. However, the output turns off as long as I use the multimeter probing the output voltage. If the probe is connected output through a wire, the output seems stable. It looks like only shut off when I probed the output after it's powered on. Is there anything wrong with the output capacitor or the inductor needs higher value?
thanks in advance
