Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS65235: Difference between TPS65235 and TPS65235-1
Part Number: TPS65235
Hi
May I know the main difference between TPS65235 and TPS65235-1? By comparing the both datasheets, it seems like the only difference is the support of FCCM.
I have two questions:
  1. If we are not using FCCM mode, then TPS65235 could simply replace TPS65235-1, right?
  2. If the FCCM mode is used, then what needs to be considered when replacing TPS65235-1 with TPS65235?
Thanks.
