Hi Team,
May I know the gate pin peak source current of LM74722-Q1? Our customer will use total 4 MOSFET to conduct total 420A current, the source capacity will guide us the rough turn on time of MOSFET. Thanks.
Hi Team,
Hi Wiky,
The Gate pin source current for LM74722-Q1 can be calculated using the tGATE_ON(DLY) parameter specified in the datasheet.
As you can see it takes 0.8 us for the LM74722-Q1 to charge a 10nF gate cap to a voltage > 5V. Using I = C* dv/dt equation, you can back calculate the Igate.
Hi Praveen,
Thanks for your guidance. Per these two parameter, the Igate will be about 62.5~136mA level.
Hi Wiky,
The tGATE_ON(DLY) includes the 'fixed internal delay to turn ON the GATE' + 'Time taken for the Gate-A voltage to reach 5V'.
The 'fixed internal delay to turn ON the GATE' will be pretty much constant. Hence for for higher gate cap, you will see the 'tGATE_ON(DLY)' will be relatively faster.
Hi Praveen,
Thanks for pointing out the delay time. I try to set the delay time to a constant value, and 30nF capacitor charging time will be 3 times of 10nF, so Igate will be 333mA finally. 10nF charging time is about 0.15us.
