Hello:
The FG used in our current project is bq27542. Please inquire about the Value of cut-off current of this FG and whether there are relevant setting methods. Please also help provide it,
Hello:
Hi Jimmy,
Can you clarify exactly what you mean by "cut-off current"? This could refer to many different parameters on this device such as taper current, quit current, or dead band current. If you could provide so more detail on this I will be happy to advise you going forward.
Jackson
Hi Jackson:
"Cut off current" refers to the current when charging is stopped, or I see that the Ti document introduces a "full charge termination detection", which has a condition that averagecurrent() is < taper current. Here's taper current. Please help confirm whether it can be modified and how to modify it. Thank you!
Hello Jimmy,The driver can send the commands to change data. The commands are detailed in the TRM. We do not recommend changing values after the pack is manufactured. We recommend that all values be set before cells are attached to the pack.
Hi Shirish:
Please help to give the specific method description of modifying the taper current (or point out the specific location in the TRM). We need to do some verification in the early commissioning stage to avoid problems such as unable to fully charge the battery in the later stage, which will affect the product quality
