Hi Team,
Our customer would like to clarify about the high level output current of TLC77-EP. According to our customer,
Electrical characteristics table in the current datasheet revision for Output Voltage (high and low) specify a case of an output current of -20mA. This differs from the DLA V62 drawing, which specifies 2mA.
Can you verify that the current TI datasheet is correct in this instance? It appears that the TI datasheet used to agree with the V62 drawing at 2mA, but a datasheet revision in ~2006 changed the 2mA to 20mA.
Danilo
