Dears,
Our measurement value result is below 20ns, is any way to adjust?
or this is not critical item can be waive?
BR
Eric
Dears,
BR
Eric
Hi Penny,
If signals too fast will effect communication? or it's ok will not cause any warning?
In my opinion signals too fast seems like didn't cause problem if adjust capacitance and resistance not working.
BR
Eric
Hi Eric,
The rising and falling time being less than the spec shouldn't cause functional failures but it is not compliant to the I2C spec. Thanks.
Hi Penny,
Is any chance to modify rising/falling time criteria?
Possible cancel minimum value?
BR
Eric
Hi Eric,
We can't modify our datasheet spec as this is I2C compliant spec. You can add resistors and capacitors to increase the rising/falling time to be compliant. Thanks.
Penny
