TPS65721: After removing usb power cable, device is stuck in CH_RESET mode (in reg CHARGER_STATE)
Part Number: TPS65721
Hello. The issue stands and i'm quite lost. THRESHOLD connected directly to the DCDC1 output (3.3 V, tested and works as intended), without voltage dividers (pin connected directly to DCDC1 via 499KOhm resistor).
After connection of the usb cable, state changes to Precharge, then to CC_CV.
Can you tell what is wrong?
Sincerely,
Maxim Hodnenko
