Hi
The datasheet says that TPS62067-Q1 devices has a built-in clock-dithering circuit. I am wondering what is the operation frequency of the build-in dithering circuit?
Thanks.
Hi
Thanks.
Hi Darren,
TPS62067-Q1 device has internal clock dithering circuit and its oscillation frequency is slightly modulated with sub clock dither of typically 6ns.
Can you share more detail on application? Let me know if you need further help!
Tanvee
Hi Darren,
Does this ripple/signal go away when the TPS62067-Q1 is tested in forced PWM mode under the same conditions? and can you share schematic and layout to check ?
Tanvee
