Other Parts Discussed in Thread: TPS62912
I need to ensure that the power supply has the lowest noise and ripple possible, and would like to ensure that my layout does not cause any issues. Any tips?
This is a common question, and a good one! Although the TPS62912 and TPS62913 are designed to operate with very low noise and ripple, the layout can impact the system performance. The datasheet is a good reference for the layout considerations, as well as the app notes showing implementations with ADC, AFE, and clocking solutions (see references below).
A proper layout is critical for the operation of any switched mode power supply, especially at high switching frequencies. Therefore, the PCB layout of the TPS6291x demands careful attention to ensure best performance. A poor layout can lead to issues like bad line and load regulation, instability, increased EMI radiation, and noise sensitivity. Refer to the Five Steps to a Great PCB Layout for a Step-Down Converter Technical Brief for a detailed discussion of general best practices. Specific recommendations for the device are listed below.
References:
TPS6291x datasheet layout section: https://www.ti.com/document-viewer/TPS62913/datasheet/GUID-EF63E7C9-0CE2-440E-87E9-643CD9393215#TITLE-SLVSFP4TOCWRAPPER_LAYOUT
Design considerations in the app note for using the PTS62913 to power noise sensitive ADCs: https://www.ti.com/lit/an/slvaew7/slvaew7.pdf?ts=1641175545084&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FTPS62913
