The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LM2937: 3.3V
Part Number: LM2937
Good Day. I have a customer who is working with LM2937ET-3.3/NOPB. Please see below his query for your reference. Thank you very much.
I'm looking at the datasheet for the LM2937ET-3.3 (LM2937ET-3.3/NOPB) and I've noticed section 6 appears to be missing information on the 3.3 version of this product family. I see specifications for the 5V, 8V, 10V, 12V and 15V versions, but nothing for the 3.3V. While I don't think most of this information will be especially critical to our specific use case, I thought it would be important to share this discrepancy.
I would like to confirm the min and max output voltage of this device however.
Ray Vincent
  • Hi Ray,
    Thanks for sharing. I'm not sure why the 3.3V version is not specified, but the good news is that many of the EC specs will be better with lower VOUT, so using the 5V specifications as a reference will serve as a beyond-worst-case scenario.
    Do you mean the abs max?
    Nick
  • Hi Nick,
    Yes, like on the table for 5V and so on. Thank you very much.
    Ray Vincent
  • Hi Ray,
    I found some test data for the 3.3V version, but it's only at room temperature and does not quite constitute the same min/max as the other tables in the EC section. What I can give you is the mean and max, where μ +/- 6σ can be used as the limits. Here is the data for room temp:
    Parameter Tested Condition Mean μ  STD_DEV σ
    VOUT Vin=5V, Iout=5mA 3.29481 0.00751488
    Vin=5V, Iout=400mA 3.3028 0.00816501
    Nick
