TPS543320: Fly-buck compatibility
Part Number: TPS543320
can you please confirm that TPS543320 is compatible with fly-buck operation? I use the part already on the board, and I'm in need of some +- voltage rails for op amps.  The part is forced PWM, the negative inductor current protection should be enough for my application. I was not able to find any other show stopper in the datasheet. Thank you for the confirmation.
Jan Petrik
