CSD88537ND: Alternative to Competitor part...
Part Number: CSD88537ND
Other Parts Discussed in Thread: CSD88539ND, CSD17577Q5A
I know this is a long shot, but I am supporing a request for a replacement to HAT2195R.
Datasheet
This device has an SO-8 package, but the only "same package" I can find is CSD88537ND or CSD88539ND; except they are dual MOSFETs in a single package.
1) Could you tie gates together, sources together, and drains together to make them parallel, and "act" as a single MOSFET?
2) Is there any device with similar specs you could recommend with the SON-5x6 package? I know this isn't leaded, but pin-pitch is the same, and the overall package dimensions add up...
I think we might be able to succeed with such a package...
  • Hi Darren,
    Thanks for the inquiry. The CSD88537ND and CSD88539ND are our only devices in SO8 package but as you pointed out, they are duals. I supposed you could connect the FETs in parallel but you wouldn't have the same pinout. As far as a pin compatible replacement, I would recommend CSD17577Q5A which is lower on resistance and slightly higher gate charge. We have some other devices with similar on resistance but they are higher cost.
    John Wallace
    TI FET Applications
