Hi support team,
At startup, an output inrush current of 9.3A occurs and the current limit is activated.
We will use TPS54620 knowing that the current limit will work.
Therefore, please check the following.
In the table of "6.1 Absolute Maximum Ratings" in the data sheet, the MAX value of PH / PVIN is "Current Limit".
We use it on the assumption that it will be current limited.
I would like you to confirm that there is no problem with the attached waveform.
Is there a problem with the energy of I2t for the built-in FET?
TPS54620_Current_Absolute_Maximum_Ratings_confirm.pdf
Dice-K
