Other Parts Discussed in Thread: TPS27SA08,
I had some time for further testing the samples of the PTPS272C45ARHFR.
I didn´t find an information about quiescent current for single supply, both channels disabled and diagnostics also disabled in the datasheet.
The single switch TPS27SA08 has no current consumption at all in this state (only a few µA).
The PTPS272C45 instead shows a different behaviour. The current consumption is about 2.6mA (VS=24V), altough channels, Vdd and diagnostics are switched off.
If all connections are cut off, except VS and the connection to the load, there is still a current consumption of 0.5mA.
Is this only a problem with the preview-variant PTPS272C45ARHFR or is this normal behaviour?
With kind regards
Marc Nestler
