Other Parts Discussed in Thread: BQ33100
Hello
I'm looking to balance and charge 2 of Eatons XT3585-3R0567-R 555 farad capacitors in series. Max individual capacitor voltage is 3V, ESR 2.6m Ohms, Leak Current 1.30 mA. The power supply to be used output is 5.060 volts and 3 amps max. Will the BQ33100EVM-001 be able to charge and balance the capacitors with this power supply? What is the minimum volt amps required to power the BQ33100EVM-001?
Thank you,
