I am using the BQ24250 ic as charger for a 1 Lithium cell battery. The problem is that the voltage in LDO pin is about 2.15V instead of 0V when no input is connected (5V rail come from a USB connector). It causes power consumption since a couple of resistors is connected to TS pin and GND.
Do you have any ideas?
Thank you in advance
Here you can find the schematic.
