Other Parts Discussed in Thread: TPS22998
Hi
We would like to isolate a Li-Poly Battery Charger IC+Battery from the remaining system circuit.
The purpose of this isolation is when the battery voltage drops very low, we would like the charging to only charge the battery.
We would like to force this SWITCH OFF when the battery voltage is less than 3V and back ON once the battery is 3V+. If this is not possible we can manually control the Enable on this device using a toggle switch.
We have chosen to use TPS27081A, as we are currently using this device on various PCBs already and have them in stock.
Or is there any alternative solution?
