Other Parts Discussed in Thread: BQSTUDIO, USB2ANY, EV2400, BQ25790, BQ24179
According to a similar post:
BQSTUDIO only works with EV2300/2400.
GUI Composer, which we will be using with all new devices, only works with USB2ANY.
In the design guide:
https://www.ti.com/lit/pdf/sluuc51
I see steps on how to use the eval board along with BQSTUDIO, but no details on how to use it with GUI Composer. Is there a similar walk-through/guide on how to use the eval board with GUI Composer specifically?
As I am not familiar with development using USB2ANY nor the EV2400, I want to ensure I can do everything with the USB2ANY+GUI Composer that I would otherwise be able to do with the EV2400+BQSTUDIO before purchasing one or the other. If I need both for whatever reason, please indicate why this is the case.
Along the same line, would the combination of either be more helpful when trying to design a custom circuit using the BQ25790 family of devices, e.g. (BQ24179)? Rather than programming all the serial protocol listed in the datasheet, does either combo (USB2ANY+GUI Composer) or (EV2400+BQSTUDIO) reduce development time with some sort of API or the like that implements all the serial protocol details?
Christopher
