Other Parts Discussed in Thread: TPS7A85, TPS7A84
Hi TI Team,
I have a question on TPS7A8300
We have power supply rail as above.
First of all the 1.5V is output from buck converter, and then ANALOG_0.9V is enabled before ANALOG_1.2V, and the FPGA leaked the voltage before ANALOG_1.2V is enabled.
So we have the ON and OFF waveform as below. There is some leakage at ANALOG_1.2V but it does not exceed 0.9V.
My question is;
Will this leakage give any effect to the ANALOG_1.2V LDO in terms of operability and reliabilty?
We dont want to add additional load switch or change the LDO due to design constraint.
Best Regards
Naim
