Hello there,
Does the BQ25892 have reverse polarity protection? It is a battery charger therefore it is more than just adding a diode, especially for a portable device. Do you have any recommendations towards this end?
Ashwati
Hello there,
Ashwati
Ashwati,
The charger does not have battery reverse polarity protection. Please refer to the application note Reverse Current/Battery Protection Circuits at https://www.ti.com/lit/an/slva139/slva139.pdf for the details.
Ning.
Hello Ning,
Thank you for the clear response - the document you have listed shows 2 methods, the diode and the transistor version for reverse polarity protection. However, I am using the BQ26892 for a portable device, and the above methods are not recommended for battery chargers because they act as both sink and sources (Ref: https://www.edn.com/reverse-voltage-protection-for-battery-chargers/).
Are you aware of any solutions or application notes/reference designs that TI has that suggests a clean design for reverse polarity protection for designs with battery chargers?
Ashwati
