Other Parts Discussed in Thread: TPS2116
Hi Team
Could you help the customer with the TPS2121 for the Automatic Switchover Between Two battery Supplies?
IN1 and IN2 both inputs connect simultaneously, the TPS2121 should use the higher input to the output that means if IN1 is great than IN2, output IN1. or versus. it works like a oring.
Looking forward your reply
