Other Parts Discussed in Thread: BQ25306
Hi team,
Would you please answer following questions?
1. BQ25672 doesn't have voltage output pin which is in proportion to the charging current, only can read by REG33 IBAT_ADC_15:0, correct?
2. When WDT is expired, BQ25672 doesn't stop and move to default mode. If users want to stop charging, users should read /INT and stop via I2C.
3. Charging current limit can only set by ILIM_HIZ pin, correct? IINDPM_STAT is pulled high when overcurrent, correct? Please let me know if BQ25306 has other current limit setting or other overcurrent indicator.
Hideki
