TPS7B7702-Q1: Single Channel Usage
Part Number: TPS7B7702-Q1
Other Parts Discussed in Thread: TPS7B7701-Q1, TPS7B7702
Only for the SENSEx pin, it is given that  it has to be grounded if not used. I wanted to know the effects of leaving the second channel pins open(floating) and using only the first channel pins. There is a single channel model available in the same series, but wanted to know the implications of using the 2 channel IC.
Also if you could suggest any pin compatible IC for TPS7B7701-Q1 would be really helpful.
