Other Parts Discussed in Thread: BQ24072, , BQ24040
continuing with the question, wether I can use a BQ24072 on the the example of Pag 32 of the bq51050B datasheet (Figure 37. Wireless Power Receiver and Wired Charger)
The BQ24040 on the application has only one pin (OUT) to charge the battery and supply the system.
However, the BQ24072 has one OUT pin to connect the System and one BAT pin to connect to the battery and charge it.
There is a FET (Q2) connecting both pins internally.
My question is: is it possible to tie BAT and OUT externally together?
Thank you in advance for your help,
Gustavo
