Other Parts Discussed in Thread: INA280
I am trying to regulate the maximum input current of a flyback converter using the LM5180. I am measuring the input current with an INA280 and comparing it to a reference with an opamp. Can I drive the SET pin from the opamp output through a resistor/diode to regulate the input current? This will require sourcing current into the SET pin/resistor to lower the output voltage.
David
