HI team,
I understand DCDC converters with DCAP has comparator with 7V Vcc, so output voltage is limited by under 7V. Please help the following questions.
1. In case customer set resistor divider to typical 7.0V, due to variation of resistor and Vfb, output voltage will be also limited by 7V, never exceeding, right?
2. If customer set resistor divider to typical 7.0V, what behavior will be expected such as not working, broken, voltage decreasing or so on?
Hideki
