Using 13k & 49.9k for the resistor divider gives output voltage of 3.9V. This is significantly different from the formula given in the datasheet. 10k & 49.9k gives 5.4 V. The following is the schematic. The switching frequency is set to 1 MHz using the recommended resistor value. Any insight would be appreciated. Thanks
