Other Parts Discussed in Thread: LM74800-Q1
Hi Team,
The LM74700 has an EN pin, which is described in the datasheet to turn off the LM74700 and the N-mos gate, but the body diode of the N-mos is still turned on, and the Vout power supply of the subsequent stage will not be turned off.
So this EN Pin cannot be used to turn off the power supply of the power stage. Is this understanding correct?
In addition, if this is understood, what kind of scenarios will this EN pin be used in?
