Other Parts Discussed in Thread: LM53602
I created LTspice circuit model using the library data of LM536023QPWPTQ1 on the Web and performed a simulation.
There was a terminal called PAD for the model created from the library data. How should this terminal processing be done?
I send you LTSpice circuit model and the library data that was on the Web, so please check if there is any problem with the circuit model.
Also, if you perform a simulation with LTspice using this circuit model, it will take a considerable amount of time to complete the analysis.
Would you please tell me if there is any technique to reduce the analysis time?
