I would like to change the output voltage of this device by utilizing a handful of properly spec'd resistors and a rotary switch, to change the resistance along the path between the ADJUST pin and GND. Is this a suitable method for this device or should I be looking at more continuous methods of changing the ADJUST resistance?
Thank you
