TPS92381: TI solution suggestion
Part Number: TPS92381
Other Parts Discussed in Thread: TPS61177, TPS61196, TPS92391
Dear Team,
Do we have any suitable solution can meet below backlight led spec?
Many Thanks,
Jimmy
  • hi Jimmy
        first of all, we do not have device supporting up to 15 channels. Now we can have two possible solutions:
    1. rearrange configuration of LED by decreasing channels and increase total forward voltage. If this is accepted by customer, then we have TPS61177 or TPS61196 for 9s5p
    2. take 3 strings as a set, total 5 sets. each string in the same set share anode and cathode, the common cathode will be connected to one channel of the device, then we just need a six-channel device. In this way, TPS92391 or TPS61196 can be options. But obviously, the brightness uniformity is not as well as first solution.
