Other Parts Discussed in Thread: TPS7A47
My application requires having a positive voltage source(9.7V) which should be capable of sinking in 400mA of current. I could not find any such LDOs or SMPSs which have current sinking capability in this output voltage range. I found this article which suggests using a negative voltage LDO to generate a positive voltage and using the inherent capability of the negative voltage LDO to sink in current.
I was thinking of using TPS7A33 in a similar fashion to generate a output voltage of 9.7 V which could sink in current. I tried to simulate the PSPICE Model in TINA and Ltspice but it does not seem to work. I am not getting any Vout (1.8uV). Can you please tell me if it is possible to use TPA7A33 in this particluar application in this configuration. If not, can you suggest any other alternative. Thanks in advance!
