Other Parts Discussed in Thread: BQ24610
Hi Team,
Customer is using BQ24600 on their board for charging a Li-ion battery. They changed the battery chemistry to a lead acid battery. They're in the layout phase and don't wish to make changes to the schematic and look for new parts. Also, would like to hold the IC in case we go back to Li-ion.
Can the BQ24600 be used to charge a lead-acid battery, or would they need to use the BQ24610?
I found TI document SLUA992, which talks about modifying circuits around Li-ion charger IC to be compatible with lead acid battery. Their application is a backup application as per section 2.2.
Based on my understanding, they should not do any changes to the BQ24600 and be able to use it because the charging profile for backup application in SLUA992 Figure 3 is same as the charging profile in Figure 5 of BQ24600 datasheet. Or would there need to be modifications to the circuitry? Could you please advise?
Thank you,
Delaney
