TPS22918TDBVRQ1 , we are using this part in our design, In revision 5 we were using 100pf @ CT pin board was working normally. Later in the updated revision with delta changes and PCB material changed
We are seeing reboot when the TPS22918TDBVRQ1 switch is turned ON. We tried for around 30 to 40 times same issue observed consistantly. In the same board when we probed for rise time @ the output pin of switch we have not seen this issue. later we checked multiple times issue not reproduced.
Samething repeated with board 2, board3, board 4.
Until we probed issue was there once it is probed issue does not repeats back, why this is happening what is the logic behind this not understood.
Also, let us know with PCB revision change with very minor delta change why we are seeing this issue how to resolve.
