Hi team,
Could you advise how much is the PSRR of TLV73311-Q1 at 1MHz?
I see TLV73318 spec on the datasheet, but I would like to know 1.1V version up to 1MHz.
regards,
Hi team,
regards,
Hey Shinji,
The PSRR of the device will not be impacted much by output voltage.
From the datasheet(https://www.ti.com/lit/gpn/tlv733p-q1) figure 6-9:
It depends more on if an output capacitor is being used. If so, The PSRR looks to be around 18dB.
I hope this helps!
-Jimmy
HI Jimmy-san,
That picture matches to my bench test result, but the datasheet specification seems not match.
You can see below 28dB at 100kHz while the Figure 6-9. looks 18dB.
regards,
Hey Shinji-san,
This looks like it may just be a typo and should be 18dB at 100kHz. We will leave a note to have it fixed.
I hope this helps!
-Jimmy
